I used duplicolor on my car in 2004, but it is already chipping off. Just in front of the rear windshield, I scrapped, primered, repainted that metal piece (separates the windshield from the roof) and it is also cracking/chipping...any suggestions for this?Robb said:
I used did sandpaper it as well as used a primer that was supposed to be compatible with Duplicolor paint.stickershop said:Did you sand it with a light grit sandpaper before shooting down the primer? Is it possible that you're using a primer that is incompatible with the duplicolor black paint?
How long ago did you use it?Charles said:I have been VERY happy with Forever Black. I will give a progress update over time in the other thread. But it looks brand new right now.
Where can I get Forever Black?fireant said:Forever Black worked for me... its a permanent dye. Someone else made a good suggestion about Forever Black, take the sponge applicator off and wipe it on with a soft cloth, it will be a smoother application. Also, do multiple coats...each coat is about 10% blacker.
Its not a coating like paint, but a dye, like a marker, so it wont chip. Its held up for months without any signs of fading yet.dohcya said:Has it faided or chipped fire?
