Hey guys, Im contemplating wiring up some thicker gauge power wire activated by relay to power my Walbro 255 in tank pump. Im confused on the possible locations to crimp the actual power though.
I was under the impression that the yellow/black wire above the cover was the power wire, but there is also a yellow/white wire. And once you take the cover off there is another connector plugged into the top of the tank with a yellow/white and a black.
When Im doing the direct wiring, would it be best to go all out and cut open the harness below the cover, drill a hole in the cover and run my new 12 gauge power wire and ground and connect as close down the wire as I can reach/solder without actually dropping the tank...
Or is it just the same to cut the power and ground wires above the cover at the harness connector there...?
What is the yellow/white and seperate ground for?
Just trying to see how you guys have done this before I have a go at it
