Hey guys. As many of you know, I'm undertaking a huge restoration project on one of my SE's. As part of the project, I'm battling with some rust issues. I've sandblasted the front half of the car, and i'm replacing rust areas with new metal. I plan to paint the bare metal with POR15. However, since I want a perfectly smooth finish, I want to spray it on.
I'm a little weary about using POR15 in my spray gun since it could permanently gum it up, so a hot-rod guy on another forum recommended that I use a disposable Preval Sprayer to shoot the POR15 onto the car. It is a compressed air cannister with a jar on the bottom to hold whatever type of paint you want to spray. The kit was only $7 at my local parts store and refill air cannisters are $5.
Here's what I was told about the gun: The advantages of it are that it is very maneuverable and can do little jobs without much cleanup or wasted paint. It also sprays a lot less material at a time than a regular paint gun. This can be an advantage if you're a novice like me. (It's a disadvantage if you're using a fast drying paint...fortunately POR15 is not fast drying). A disadvantage is that the spray pattern won't provide you with a perfect finish like a normal spray gun... however, since this is my bottom coat (POR15 > Primer > Base > Clear), I should be able to smooth it out with some light sanding between coats.
http://www.prevalspraygun.com/
Has anyone here used a Preval Spray gun for anything? Any comments?
