I have a handful of prewired kits I have made for Retained Accessory Power. This allows for the Radio and accessory circuit in the vehicles ignition switch to retain power UNTILL the door is opened.
I've had this wired into all of my cars and always had it be useful.
Here is an example of a kit I have produced..
Simple. Comes with everything. Grounding screw, ziptie, wires pre-cut (and LABELED) and relays are clipped together for easy installation. I'm only asking $15 Shipped for my friends here at the CRXCommunity.
Another circuit I have implemented into my cars is a security feature.
There are two types I have used. One is latching normally open and the other is non latching.
The purpose of these is that the car CANNOT be started until a secret switch is depressed and/or held (depending on which kit you want)
I prefer latching because you can hit the hidden button once and not have to hold it in while you start the engine.
Non-latching is also good security if it is made aware that you DO have a starter kill in you car, and the switch can't just be pressed once.. Ideally, this means that someone would be pressing every button you and switch you have at the same time (not possible) and then turning the key as well.
Of course, I've also done a combination starter/kill and push-button start.
If anyone has any ideas for something they would like electronically in their vehicle, please feel free to let me know. I'm always interested in new ideas.
I've installed pretty much everything in vehicles over the years. From super rice, to clean and classy.
Also, I have worked for FoMoCo as an installer.
Thanks for reading,
~Rocco
Thanks for reading,
~Rocco
