1 - 4 of 4 Posts
Well, for a short while, I patched my ipod directly into a 50 watt power amp, and that worked sort of ok. The level output by the pod is significantly lower than than from a head, so you take a good hit in volume. Also, there was (obviously) no way to control balance, etc. You could use a preamp, but at that point you might as well have a head unit, even if it's stuck by in the security cubby.
Is that what you are thinking of, or do you have something else in mind?
1 - 4 of 4 Posts
