1 - 3 of 3 Posts
i havent tried the thermostat ground yet i will try it 2nite when i get out of work.
I swap in a d15b7 after the swap i had no spark or fuel and i can not figure it out. So far:
New ecu
New distributer
New main relay
new coil
checked all fuses
help would be cool
did you go through and double check everything?
-check your fuel resistor box plug
-this might sound stupid but check if the ecu is plugged up i forgot once haha :oops:
-uhh check your starter ground
-check you main engine ground
-other than that the only thing i can think of if maybe your ignitor in the dizzy unless you bought a BRAND spankin NEW ONE!!!!!!!
i have no more ideas man!!! sorry i cant help much this is all i can think of
1 - 3 of 3 Posts
