1 - 3 of 3 Posts
I used to have a page that told me all this but it's long gone. I need to know if specific 88-89 parts (probably from a junkyard) will fit my rough n' tough '89 CRX HF:
- Will a driver's door from a hatchback or 4-door fit, assuming it's the right year (I need pillar mounted version, some '89s and all 90-91 CRXes had door mounted belts, making the window to be an inch or two short, other models should follow suit)
- Same question, but for the passenger fender. [will a hatchback, or 4-door fit] (90-91 fenders have a different mounting setup for the corner lights)
- My '92-95 D15Z1 (VX) engine came with a beat and dented to heck oil pan. Can I swap my D15B6 ('88-91 HF) to it or are the baffles designed different (to my knowledge both engines have a factory oil cooler mounted to the oil filter site, so I figure the pan is special and model specific too)
any info is appreciated, Thanks, Mak
if you have more of these type of specific quesions about what is same/different between the crx years post them here. There are a lot of things lef tout, or unspecified in some of those online lists and tables of similarities and idfferences.
1 - 3 of 3 Posts
