1 - 11 of 11 Posts
Something is wrong with the relay, or there's a short. The fan, even when wired correctly, rarely comes on.
Jeff, you should address your overheating problem, not just leave the fan on. The car shouldn't overheat normally.
baker_jeff said:
I wired mine up to do just that yesterday, because my car was overheating like a mofo.
Hmmmm... that's like a band-aid on a wound that requires medical attention. Make sure you try to find the root of the problem. It could be more serious.
#23 is the fan switch
remove the plug and start the car, fan should be off
jumper the switch with a paper clip or something, the fan should turn back on
if all conditions are true then the fan relay is ok
Discussion Starter · #9 ·
First I would like to say no F'n way I'm I going to fight my way back there again. The first time was with SETI and that took FOREVER. Second time I was replacing the intake so it wasn't to bad. Short of removing the intake again I could care less now. I give that switch the middle finger nay the double dueces is what that thing deserves. Thanks guys but I'll wait to fix that little piece of shizer.
· Premium Member
It's not that bad. If you have some good jack stands and a creeper, you can work your way back there pretty easy. Once you know what you're looking for, it's fairly easy to spot and get to.
1 - 11 of 11 Posts
