1 - 10 of 10 Posts
For 2nd gen. Normally you pull the old ones off and carefully press the new ones on. I've never replaced the clips. Try marking where the clips are with tape and press on that area when installing the gutters.
I've tried like 10 times, can't get the clips to grab the seals. So it sounds like I am doing it right, just gotta get lucky and hope the clips attach. Wish I had xray vision so I could see where I am missing.
Thanks.
I as well would like to know how to even remove them! I figured you don't just peel them out... I thought maybe slidding it from the back, but I don't know. If someone had a diagram of the roof I could figure it out, it's a hatch tho, not a Rex.
rex2nr said:
I ripped mine out since they are pretty much a 1 time use piece
One time use eh, well, Honda have replacements without it costing me my left nut? The more I learn about my body, the less I wanna fix it, but I know I will.
I'm bet you can get at the clips from above the headline, remove the clips and then install the clips into the strip, then reinstall...
Someone can probably remove them properly, but when I pulled mine out, they became "C" shaped and wouldn't bend back, so they ended up in the dumpster
Mine are pretty dried out and have little cracks in them, I have a feeling mine are gonna be a 2 peice item by the time I get them out.
1 - 10 of 10 Posts
