Filing the Ring Gap
When you receive your new rings, you will place them in the cylinders and measure how much clearance is left at the ring gap at various points in the cylinder. Slipping feeler gauges into the gap lets you determine if the clearance is sufficient and matches your tractors suggested specifications. To increase the ring gap, spread the gap enough to insert a file and move the ring back and forth occasionally checking the gap in the cylinders till you reach the desired clearance.
http://www.ytmag.com/articles/artint10.htm
