Any idea how much both side windows cost and roughly how much it would be to have them installed?DAP91Si said:I've replaced the rear side window trim. I've come to the conslusion that to properly install them the window must be removed and the trim/window installed at the same time.
That doesn't mean it can't be done. The trim has a plastic tab that goes into a hole but impossible to do with the glass on. I cut the tab off and filled the hole with silicone. Also removing the garnish in front of the rear window helps. I glued them back in with liquid nails.
Good info I need a pair of those.jfrolang said:A phone call to a local auto glass shop could probably answer all your questions.
Honda has a list price of 27.12 per side for the quarter glass trim.
