1 - 13 of 13 Posts
If you are removing the bumper in your driveway, I suggest putting a blanket down on the ground under the bumper so you don't scratch it when it separates from the car.
-Remove the corner markers (two screws on each on the outside)
-Remove the bumper turn signals (two screws on each) Disconnect the plugs and remove
-Remove the two screws on the bumper lip just in front of the tire (both sides).
-Remove the 10mm bolts under the car that attach the bottom plastic of the bumper to the crossmember
-Remove the 12mm bolts in behind where the turn signals were (2 on each side of the bumper).
The bumper should just pull off the car if it hasn't separate already. You're done! Installation is the reverse of removal, but may take a little extra time in getting it aligned properly.
baker_jeff said:
Savage said:
im putting angel eyes on tomorow. i'm pretty sure we need to take off the front bumper will it be the same process?
It will be. I'll be tearing my bumper off soon for IC fitment, glad you bumped this thread!
You better not cut that bumper for the IC. You would be better off selling it to me. :lol:
I don't recall taking the corner lights off when I removed my bumper to install my angel eyes on my 88 Si. Are they THAT different between the years?
1 - 13 of 13 Posts
