Ok guys, I tried everything that you suggested about removing the rear motor mount bolt, and I couldn't get it to work. With my fat fingers and big forearms, I could not reach inbehind to get a socket and swivle onto the bolt from behind the motor mount. I even tried dropping the crossmember a bit to get into there. I can only conclude that I am OWNED by the rear motor mount. It is inconceivable that it would be that difficult to remove one stupid little bolt. I would basically have to partially or completely remove the rear crossmember in order to get the rear bolt out. ARGH!!!
