1 - 3 of 3 Posts
so today i finnally got my key so i could get back into my crx. after taking apart my center console to try and fix my cigarette lighter i shut off my car went to work and came back when i turned on my car the clock didnt' work it only lights up when i press the button cover down. there is a little button in the top right corner of the button housing that will turn on the clock does anyone know how to fix this.
second of all, before i lost my only key my car got broken into. the thieve(S) used a flat head to pop slip under my handle and unlock the door. now my driver side door doesn't lock or unlock from the outside only from the inside if i take off my door cover (what ever you wanna call it) is there something i will need to repleace or is ther something i will need to simply adjust?
Not sure as to the door handle, but the clock is not recognizing that the car is on. That button is used to turn on the clock when the car is off (when you press down the cover, if yours is still on there). Check the wiring on the clock to see if any of the wires are loose. It's still getting power, so it has to be a switch wire.
You probly popped the fuse for the clock.
There should be a rod that is/was attached to the door handle from the latch, look to see if it's still there.
1 - 3 of 3 Posts
