1 - 4 of 4 Posts
I have a scanner mounted in my car and im looking to put the antenna on the right side of the car. The radio antenna is on the left side and i want something that will look as stock as that for the scanner antenna. Any ideas?
I don't know what connection the scanner wire has, but I would check to see if it is the same as the radio antenna. If so, I would buy a stock antenna (I think they run about 25 at Autozone, and have the same trim as stock), drill three holes, and mount it symmetrically to the radio antenna.
There two different connections. The radio one you push into the back of a radio, where the scanner one is an open end that is put on a connector.
1 - 4 of 4 Posts
