Hey guys/gals,
I just finished swapping my d16a6 from my unfortunately wrecked 91 Si, into my *new* 89 Dx. I swapped *everything* over. I didn't want to be splicing wires and such so I stripped the interior of the car and pulled all the harnesses and carpet and dash and seats and blah blah blah from the Si. Took about three full afternnons of work to pull everything over. I've still got to swap the rear disks and suspension, but I'll leave that alone for a few weeks.
Right now my question is about the idle. In my old car the idle would sometimes dip down a bit lower than 500 rpm (stock tach) and be a little rough. Just a little. But most of the time it was fine.I put all the fluids in and started it up now that its in the new car and the idle seems a little more rough than it was. Granted it now has good motor mounts in it, so I'm trying to take that into account. At first it idled around 1,000 rpm til it warmed a bit, then dropped down to 500-800 rpm zone. But as i drove it around a bit i noticed once it wanted to idle high around like 1,200 rpm for a couple minutes, then someimtes it would dip low again.
The power at mid and open throttle is great as usual. This engine is very tight and strong. So what gives? I thought vaccuum line, but they all appear to be connected properly.
Suggestions?
P.S. sorry for the long post
Suggestions?
