So I'm on my way to chem lab tonight, maybe a bit behind schedule, so I'm pushing the car a bit on the freeway. All of the sudden, the speedometer needle drops from 70 (or so...) and stops at zero. The odometer is also dead. I'm thinking "speedo cable must've popped out."
Not 15 seconds later, the car acts like I turned the key off, no power at all. I push in the clutch to keep me from holding up traffic, and stomp on the gas to see what it'll do. The engine stays between 3k and 4k, revving up to 4k and then cutting till engine speed reaches 3k, then revving back up to 4k, back and forth, back and forth.
If I let the engine speed to fall below 2k with the clutch still in, and stepped on the gas, it would rev all the way up to the fuel cut. I could then release the clutch and get back into gear, and drive normally for a bit. Then it would do this weird stuff once again, a total time of 5 times in a few miles.
Any ideas of what could be the culprit? Any relation to the speedo cable? I have since replaced the speedo cable, but have not ventured back onto the freeway. I am also OBD1.
Things that I've been thinking about:
New OBD1 distributor from the Distributor King 12, 000miles ago
Any input the ECU needs from the speedo?
Fuel pump maybe going?
And I was planning on driving 600miles to Oregon this weekend...
