downest said:
For the MPFI swap you need a MPFI intake manifold, ECU, injectors, distributor, resistor box, and a soldering iron.
Exactly right!
The wiring in the hardest part, it's very intimidating for some people but if you follow the instructions and ask questions you'll be fine.
Here:
http://tech.hybridgarage.com/tech/4gtec ... wiring.htm
This is for a ZC, but the only difference is that the Cylinder Position Sensor wires, which are the same colours, are external on a ZC instead of being on the main distributer plug - if you're confused, don't worry.. it will make sense when you do the conversion
and here:
http://www.hondata.com/techwiringpw0.html
This link is a nice reference to the way the pins are laid out, colours and functions.
and finally:
http://www.honda-tech.com/zerothread?id=1191491
This link shows you how to remove pins from the ECU plugs. Cut off some ECU plugs at the local auto wreckers leaving plenty of wire. This takes some practice.
Use solder and good quality heat shrink for all connections(the good quality stuff looks dull vs shiny) I like to double up on the heat shrink when two connections rub against eachother. Most importantly, take your time because it will prevent huge headaches down the road.
Good luck, you will learn a lot doing this conversion. :wink:
