My newest addition to my CRX family had a dreadfully squeaky clutch pedal, and it was driving me crazy. If anyone else has this problem, it's actually a simpler fix than you might think.
First, disconnect the spring. Take a 14mm wrench and remove the nut that holds the pedal onto the pivot point. Remove the washer and the plastic bushing. Inspect the bushing for wear. Slide the pedal over and inspect the other bushing as well. Mine were ok, but they were completely dry (no grease). If they are damaged, order new ones from Honda. I slapped on a bunch of grease and reassembled the pedal. During reassembly of the spring, I discovered that one of the plastic bushings that the spring goes into was broken. I ordered a new one for $2.00 from Honda, and put everything back together again. My pedal is now absolutely silent.
