1 - 3 of 3 Posts
Occasionally my 88 crx will fire, but not start. It's happened twice and when it was cold out (the 50s). after a few attempts, it starts up fine. The main relay was replaced recently so I do not suspect it. My TPS is out of spec and throws an error code all the time, would this be related?
thanks!
It doesn't throw a code when it won't start. I'd have to unplug the battery to be sure though, my code 7 is always present on my ECU until I get some time to swap out thorttle bodies. I'll do that next time it happens and let you know.
1 - 3 of 3 Posts
