The top portion of my steering wheel has begun to come apart, like the smooth finish is turning into foam. Little bits come off in worn spots on occasion. Can this deterioration be fixed or at least slowed down until I can get a replacement?
Another note: What do you guys think about injecting epoxy through the foam to glue the foam back to the metal inside? The covering has separated from the metal hoop inside: I can grab the wheel (in that worn spot at the top of the wheel) and rotate the covering a bit.
