1 - 8 of 8 Posts
There are a lot of stickies in all the forums, and I find it kind of annoying to have them all at the top. There are also a lot of good write ups that don't necessarily belong in the How-To section.
So let's get a FAQ going, I'll start with the current stickied stuff. Please DON'T post comments or whatever, just a link and a description. I'd like to keep as much as possible on the site here, so if you see a good write up somewhere else, ask the author if they mind if you copy it here, or better yet invite them over here and ask them to post it! Remember this is for stock mods only, I've got one going in the Mod Garage as well.
An asterisk* indicates an external link, please include that with yours as well.
General Info
Getting Started With Your CRX
Crx 101
1st gen (84-87) Crx FAQ's
2nd Gen (88-91) CRX Differences
Honda Service Manuals
More Factory Service Manuals
Toolbox Essentials
Reverse Part Number Look-up
CRX & Civic Parts Interchangeability
CRX Special Edition Database
ECU Trouble Codes
Special Tool Rental (thanks Matt Miner!)*
Weight Reduction: How Much Does That Part Weigh, Anyway?
PDF How-To Articles (thanks tonyguns)
Honda clips and fasteners
Engine and Other Mechanicals
Ignition Timing
Distributor Maintenance, Repair, & Ignition Timing*
Ignition Switch Repair
Rebuilding a D16A6 (similar for other D series)
Surging Idle
1st Gen Surging Idle
Alternator Replacement
Fixing a Broken Main Relay
Fuel Filter Replacement
Dropping the Oil Pan
Replacing the Rear Main Seal
Cure Overheating
Changing the Coolant
Bouncing Speedometer
Changing Speedometer Cable
Temp Gauge Not Working
Fuel Gauge Not Working or Incorrect
Fuel Tank or Pump Replacement
Timing Belt and Water Pump Replacement
More Timing Belt and Water Pump (with pics)
Valve Adjustment
OEM Bearing Selection
More Bearing Selection
OEM Bearing Sizes
Stock Compression Numbers
Remove Stuck Crank Pulley Bolt
Oil on Spark Plugs
D15B6/HF Bearing Information
Transmission, Clutch, Axles
D-Series Clutch and Gear Ratio Info
Si Transmission Identification
Removing Manual Transmission
Replacing CV Joints/Axles
Clutch and Flywheel
Input Shaft Seal and Bearing, Linkage Seal Replacement
D-series Transmission Rebuild Info
Selecting the proper OEM clutch
Suspension, Brakes, and Other Rust-Seized Bolts
Correct Ball Joint Separation (with video!)
Rear Shocks and Springs
Rear LCA Comparison
Rear Compensator Arm Bolt Siezed Inside the Body
Rear Trailing Arm Bushing Replacement
Front Brakes
Rear Brakes (Discs)
Rear Brakes (Drums)
Adjusting the Parking Brake Cable
Eliminate Steering Shaft Play
Steering Rack Rebuild
Wheel Alignment Specs
Brake Parts Selection
Rebuilding Brake Calipers*
How to change front brake pads
How to change rear brake pads
[IMG=http://crxcommunity.com/viewtopic.php?f=3&t=160778]How to change lower ball joint[/IMG]
Interior, Comfort, and Convenience
Carpet Install/Replacement
Climate Control Light Bulb Replacement
Cruise Control Install
Door Panel Info and ID
Fix a Sagging Storage Box Lid
Fixing Broken Fan Controls
Make Your Own Tail Light Gaskets
More Sunroof Switch Repair
Repairing and Re-covering Seats
Rear Defogger Fix
R-134a Air Conditioning
Replace Speedometer cable
Removing Door Panels
Removing the Headliner
Reinforce/Repair Your Cargo Cover
Removing Window Crank
Si Sunroof Repair*
Sunroof Switch Repair*
"Leaky Clutch Pedal when it rains" fix
Exterior
Brake Lights Stuck On
First Gen Panel Repair
How to Replace the Door Sash
Headlight Identification Guide
OEM/Stock CRX Colors & Codes
Rear Corner Repair Instructions
Remove Rear Quarter Glass
Sunroof Visor Info
Window Trim Restoration
t0bias said:
on the "crx differences" link; i would like to see a first gen list... ya know for those of us with the ginnie pig crx's before all that fancy space-ship stuff in the newer ones.
pretty please :eek:
You know I'd actually be willing to try something like that myself.
RPR is a good site, but it is hard to get into. The are more inclusive and there is a line to get in :p
This site is a little more open to tech. But doesn't have much in the ways of the first gen. Maybe I could try posting some things I notice with my first gen? With pics? Any fixes I find? Who knows.
I'll give it a try for the sake of all the first gen'ers out there.
DerRivetBoi said:
pretty please :eek:
:)b
1 - 8 of 8 Posts
