1 - 4 of 4 Posts
superEFguy said:
I have a stock ZC and i wanna know the specs for that motor... such as Power touqe and the lift of the stock ZC cam...
Are you talking about a single-cam ZC? Or did you mean camS? I used to run a DOHC ("black top") ZC in my old car (what most people are referring to when they just say "ZC"), and I've got a SOHC VTEC ZC (an engine that a lot of people don't even know exists) currently. Both are right around 130HP, I believe...the SOHC VTEC ZC is very similar to the D16Z6, which I think is 125HP -- the cam profile is a bit more aggressive on the ZC There are other ZCs also, most notably the "brown top" (just like the black top, it's named for the color of its valve cover) which is commonly swapped into first-gen Civics/CRXs, as well as a SOHC non-VTEC model.
Here are the DOHC ZC specs...this is from dmoore's ZC page located here: http://thenew.gamesbbs.com/~dmoore/zc.htm#ZC Specs...tons of ZC info on this site, like what car to get replacement parts from, and there are several ZC links at the bottom of the page.
Bore and Stroke
75 x 90 mm/2.95 x 3.54 in
Compression Ratio:
9.1 without Catalytic Converter/9.5 with Catalytic Converter
Displacement:
1.590 cm3 (cc)/97 cubic inches
Horse Power:
~125ps at 6800 RPM
There's plenty of info out there, just search for it. A google search or a search on here or honda-tech will turn up all the info you could ever want on any Honda engine you could even consider swapping into your CRX in a matter of seconds. The forums at The ZC Resource (http://www.thezcr.com/forums/) are also a great place to get ZC information.
Bore and Stroke
Compression Ratio:
Displacement:
Horse Power:
~125ps at 6800 RPM
Good info.
Another site that has some good info is www.d-series.org
1 - 4 of 4 Posts
