i have been using heli-coils for years with great results on everything from head bolts to tranny mounts to spark plugs.... def the way to go.... then I saw these timeserts.... these look like a great product as well.... looks more like a solid insert than the wound up heli coil.... wither way. the repair will be 2 times as strong as the stock threads....
as the pressure on the bolt is divided onto the bolt threads and the threads on the part its self. . .
good luck. . .. just follow the instructions and be precice when drilling out the hole and you will be in good shape.. . . I worked in a tranny shop for 3 years and alot of our cores that we rebuilt had stripped out mounts.... we heli coiled them and forgot about them never had a proble, with them , , ,
Good luck .; .
Chris
