K well my sunroof works really great. When I first opened it I used a hex wrench. Then after I realized that the motor worked so I tried that and it also worked. Only problem is when I pressed the button it did nothing. I had to repeatedly press it to get it to move again.
This makes me think that there is a lose wire somewhere that is causing it not to work every time.
Is there an easy way to check the wiring for the sunroof?
