why is that ?downest said:... you bought one bar too many, don't install the front one.
You'll get more rotation with the stock front bar and a larger rear bar. Some people even use HF front bars. Depending on your preferences, it may make your car seem twitchy.Robb said:why is that ?downest said:... you bought one bar too many, don't install the front one.
550 LBS FRONTdownest said:What spring rates are you running?
Its on my crx. This is for my civic.cbp_crx said:hey rob. what happened to the pic suspension?
so I can use my stock brackets ?Slystone said:black braket is to hold the rear SB (or replace the OEM SI)
get stiffer rear spring rates, you'll be even happier. 8)mattminerDOTcom said:I had upgraded sways front and rear for a long time...I was much happier when i reverted back to my stock crx si front sway, and would switch to an HF one if i oculd find one.
[email protected]
not shure about to use the OEM braket and sorry don't have any writeup!Robb said:so I can use my stock brackets ?Slystone said:black braket is to hold the rear SB (or replace the OEM SI)
slystone, do you have a writeup on how to install it ?
