I'll back up the camber/toe argument...
I have a lot of camber in the front, and almost none in the rear now. I used to have 0 toe front and rear, with ~3* of camber each, no premature tire wear (I got over 10k out of my RT-215s). When I installed the SPC LCAs in the back, I reduced the rear camber to 0.5 degrees, but Honda couldn't get the rear toe in further than 0.5* out. The compensator arms were maxxed out, I need to notch them. or use some adjustable toe links. Anyway, when I took my RT-615s off for the winter after about 2000 miles of use, they were showing inner wear on the rears only. Not extreme, but noticable. So low camber and some toe in the rear, worn tires. High camber and 0 toe up front, normal wear.
