Hey guys.
So I replaced my throttle cable on saturday (which was needed-DX way too long). Now my car won't stay started. It turns over just fine and is getting fuel, it just doesn't want to stay running. When I try to give it gas at start up, it does nothing. The body opens up and everything, but it's like the ECU doesn't know that the throttle is open at all. I even disconnected the TPS, tried to start it and the car did the same thing, so I don't know what that tells me. Any clues?
Also, I have a obd0 b16 throttle body. Should I try and swap that in to see if it is in fact the tps? (I have an OBD0 DOHC ZC)
The check engine light is not going on and I haven't checked for any codes (no light bulb on the one I'm using, but I have another one at my house I can use to check codes).
Any input would be GREATLY appreciated. And I did SEARCH, but couldn't really find too much.
