Sounds like the TV cable needs adjusted. Similar in function to the kickdown rod from the carb on an old 302/C4 I had on my 75 Mduece HB.
where would i find said cable? also I've noticed it happens more when cold, and when slightly warm i can "nudge" the auto-shifter upward and it'll go into park and give me the key. I don't think there should be "play" in a park gear but that's what it feels like.Sounds like the TV cable needs adjusted. Similar in function to the kickdown rod from the carb on an old 302/C4 I had on my 75 Mduece HB.
This is a contact issue with the slide switch on the shifter. They need to be cleaned and re-greased every decade or two. Silicone dielectric grease works fine IIRC. There's a blue box under the driver's seat that blocks key removal when not in park - unplug it when the jiggling trick isn't working. It also does the push-brake-to-get-out-of-park function, so you'll need to plug it back in to drive the car. The blue box is called the interlock control unit if you want to do a search.i can "nudge" the auto-shifter upward and it'll go into park and give me the key.
