OK So somethin isn't right.
You arent supposed to use the stock valve adjustment settings on a delta stage 3 hot cam. But I cant find the proper valve lash adjustment info any where and i fear that the stock settings im using are affecting my performance. I also need to know if im supposed to run on retarded timing setings, advanced or stock for the cam as well. Right now i am at 3 degrees advance on timing. My valves are set as 008 intake and 009 exhaust
My compression tested out good at 185 psi accross all 4 cylinders
An i cant get a hold of delta camshafts. Any one here with a delta that can help me out?
87 crx si hatch stock d15 a3 motor. Thanks for any help in advance.
