Are you kidding me?????
Ya know, i seriously don't usually go after people (everyone here who knows me will say i'm very low key about things usually), but dude... you have seriously got to sit back, and read up some on how engines work, and even read up a bit on Chevy Vortec technology, and what 'Vortec' really means to a Chevy engine.
First of all, lets look at the Turbonator.... did you at all read what i said about it blocking flow, and basically being like having your throttle closed a bit? Did you know that if you don't hit the gas as hard, you don't burn as much fuel? Second of all, how is a single vorteX generator capable of separating a spinning vortex into 4 separate spinning vortex's without disrupting flow? Did you know that your TB is a flat plate, and straightens out the air flow anyway, even before this magical vortex field is created? Did you know that the injectors fire almost right on top of the valve, and the only way a vortex generation object would work, is if you had one on every port? Now, have you thought that its a dual port intake runner anyway, so the vortex would still have to split to be effective?
Now, as for Vortec..... did you know that there is no such item in a Vortec Checvy engine like what you have now shoved into your intake? The term Vortec is a marketing term that they use to distinguish two different series of cylinder head design and porting shapes... basically, a 'regular' TPI 350 shevy head is a 'factory stock' head... a Vortec head is what would be considered a 'factory ported' head basically. You can put a Votec head on a standard 350 shevy block, but you cannot swap intake manifolds.
Sounds familiar, doesn't it? well, it is sorta similar to GSR versus Type-R Heads... they both fit the same block, but one is ported much differently, and uses a different intake manifold than the other. Only difference here, is that Honda decided to not create a catchy name for the different port and intake manifold design... they just put them into different cars, and that is where they got their different names.
Anyway, i highly suggest that you do some serious reading on these things, and i DON'T mean listening to what your BoyZ think, and definitely not by reading turbonators website, where they have total control over what it says. Also, do more reading on engine theory. If you SERIOUSLY want to learn more, i have the titles of a couple of books here at the shop that are published by MIT that you could buy, and will give you a whole new realm of thinking about how the internal combustion engine functions. you'll learn terms like Helmholtz frequencies, and why these frequencies work. you'll see how using proper frequency tuning (which your stock manifold has already for its torque range) can make a manifold and intake package flow better than any little piece of metal could possibly make it flow.
later 8)
