I have an OBD0 B16A, and an 82mm bore Cometic Headgasket. Will it work?
I heard stock bore is 81mm or 81.5mm.
Are you sure? Its the wrong bore, not the wrong thickness.jfrolang said:It should be fine. It will slightly lower your compression, but you're turbo so it's all good.![]()
Yes I'm sure. :wink:Richrowa said:Are you sure? Its the wrong bore, not the wrong thickness.jfrolang said:It should be fine. It will slightly lower your compression, but you're turbo so it's all good.![]()
