1 - 4 of 4 Posts
Discussion Starter · #2 ·
MY 89 CRX DX. (AUTO TRANS) THE IDLE DROPS WHEN I COME TO A STOP. IT IDLES FINE AS IM DRIVING. 90% OF THE TIME IT WILL IDLE FUNNY IN ALL GEARS, BUT ONLY AT A STAND STILL. THE IDLE GOES UP AND DOWN BETWEEN 400-800 RPM. IVE CHECKED ALOT OF COMPONETS. IM LEAD TO BELIEVE ITS MY KN AIR FILTER I PUT ON. THATS WHEN IT ALL STARTED. I THINK ITS GETTING TOO MUCH AIR AT IDLE AND THE COMPUTER ISNT GIVING IT ENOUGH FUEL. PLEEEAASSEE, HELP!
check your grounds.... check to make sure that the coolant level is full and use the bleeder screw to make sure that no air is trapped in there..... and chack you eacv valve on the intake.... its on the drivers side of the intake on the dx model with a plug and coolant lines going into it. ..
Chris
1 - 4 of 4 Posts
