1 - 8 of 8 Posts
ok, so i have everything mechanical done for my swap, now comes the wireing. i have that mostly under control too. all i need is to hook up the VTEC sensor. if you are familiar with it, there are three connections. 2 in the green plug and one in the brown one. i was thinking of just removing the brown plug and soldering a quick dissconnect plug onto the remaining wire. But with the green plug, there are no wires and the pins are really small. i dont have the actual connectors for it, so i dont know what connects where.
i could run to the local junkyard and see if they had one, but if theres an easier way to connect it all, that would be better.
Premium Member
I'm confused..Are you asking for the wire color connections?
sorry, i am trying to find out what the wire colors are that connect to the VTEC sensor. If i'm not mistaken, these wires will be on the OBD0-OBD1 harness(that i havnt recieved yet). i just need to find out which wire connects to the 3 pins on the VTEC solinoid.
The solenoid wire is grn/yel. The pressure switch wires are blk (ground) and blu/blk (to the ECU)... It shouldn't matter which wire goes to which pin. The pressure switch connector is the same design as the EACV and coolant temperature sensor.
Premium Member
GW bob ya beat me to it. :D
Glad we helped this guy out...
1 - 8 of 8 Posts
