thank you for taking the time to read this and help! i’ll try to make this as quick as possible.
‘96 b18c gsr swapped into a ‘91 chassis and the only bolt ons are just the coil on plugs.
i’m redoing the engine harness because the wiring underneath the dash was atrocious. i’m new to modding and don’t know anything about wiring so i bought a rywire engine harness. a b series tucked obd1 harness because i have an obd1 p72 and in my hurry to get it done i forgot, i have an obd2 engine running an obd1 ecu.
besides the obvious jumper from obd1-obd2 alternator is there anything else that won’t work on this harness? or should i be fine using it? will i have to modify this rywire harness? the COP will need wired into the harness as well right? is there anywhere with a map of all the plug ins and sensor locations for the obd1 vs obd2 engine? did i fuck this up? ):
