Hey folks.
I'm trying to deal with a series of 'rex problems that popped up over the last week or so. The most obvious one was a crack that is now slowly progressing across the windshield. Ok, pretty obvious fix... I've been considering replacing the windshield just to get rid of the etched-in wiper streaks and thousand or so tiny impact specks that make street lights a menace.
Next, I noticed my fuel economy has been a little lower than usual over the past couple months... Been getting ~30 mpg where I used to get 34-40. After I got the brake-fluid-low light while taking a corner, I figured a caliper must be sticking a little, dragging and burning up fuel and the pads (thus the low fluid). So I went around the car pulling off the wheels this afternoon, giving everything a looking over.
The brakes are all fine, but the driver's front wheel bearing is toast. It's got noticable play, but I haven't heard any noise (roaring) from it yet. The strange thing is, I replaced this very bearing (I as in I had a machine shop press it in) with the appropriate Honda part about 35k mi ago when I got the knuckle from a salvage yard. I think I read a comment way back that replacement bearings don't last as long as the original parts for some reason. I thought it was just somebody that had a bearing-killing problem blaming it on the fodder, but this would seem to back up that statement.
I'm not looking forward to a $60+$35 bearing replacement every 35k miles when it should last at least 4 times that long. I don't think it's an issue of bearing quality, so then it must be a matter of installation. What's different about the typical machine shop method versus how Honda did it at the factory? Is there something I can tell the shop to be careful about? Should I give them a copy of the appropriate service manual pages or something?
Oh, and to top it off... After I put the wheels back on, I went around tweaking the tire pressures and found one wheel was 15 psi low. I pulled it back off again and found a cluster of 3 chunks of metal stuck in the tread. The first was a 1/2" long chunk of non-descript metal. The second was about 3/4" long and looked like a rusted, very old style nail... Not round, but a sort of elongated pyramid shape. The third, obviously a modern nail, about 2.5" long. :evil:
I spent about 20 mins dealing with a plug kit for the last one, no problem. But the way the chunks were set together on the tire (you could probably cover all 3 of them with a CD) makes me think it must have been a single event that put them there... Somebody setting traps of old nails on the roadways? :? Am I just paranoid, or are people really getting crazier by the day?
