Looking for a 16" wheel that is reasonably priced with an acceptable wheel weight. Anyone know how much the factory 14" Si wheels weighs so I can use it as as baseline. Also, I suspect the main reason to avoid 17s is the weight right? 215 35 17 gets you to a close to factory OD (< 5mm) so gearing should not be an issue.
