I've been running that swaybar set for a few years now. The only thing I don't like about it is the rear end-links. It uses a pair of spherical rod ends for each link which have started squeaking and rattling... I think it's because grit has entered the joint and accelerated the rate of wear. Cleaning the joints out with solvent and applying a heavy grease helps, but the problem is generally back within a month.
I guess the only solutions would be to find some kind of sealed rod ends, or fabricate some brackets so you can use more a common set of rod-and-bushing endlinks.
