so a few weeks back my laptop finally took a **** on me.
it wouldnt charge, and the battery was dying with every use. it was a progressive problem and i determined the problem to be the power jack on the mother board. i got instructions on how to disassemble the laptop (Compaq Evo N600c) and pulled the MB out, desoldered the old jack. and soldered on the new one.
while i was in there i noticed the 56k modem was attached via a mini PCI slot. so i started throwing around the idea of installing an internal Wi-Fi card (since my PC card was broken from dropping it, and it will look cleaner). i bought all the parts. and got to work.
i took it all apart. replaced the power jack on the mother board, and installed the wireless card. when booting the computer back up. it took FOREVER to load windows. on the order of hours. but eventually it loaded and everything was fine. even after more reboots, it didnt take as long. i think its because i unplugged the RTC battery, but im not sure. i did have to reset the time though. installed the software for the card and it worked great within like 10 ft (no antenna yet). and the power jack was working as well. great.
so then i had to wait about a week for the antenna to get here. got it all taken apart again, installed the antennas in the lid, put it back together and fired it up. again took forever to load, but this time never finished loading.
it would run though the start up process, (win 2k)
say "windows is starting up..."
then "preparing network connections..."
then "applying security policy..."
all normal, then go blue screen (not the bad blue screen, the windows background) and just have the cursor in the middle. after a while it will have the hour glass next to it like its working, then back to the normal cursor and there it sits. i let it sit like that over night and nothing. it never got to the login screen. and no sign that the hard drive is hard at work (no light)
so i tried rebooting to get it to kick over and then during the start-up process it would go black and say
"ERROR c-0000218 could not load hive file, dumping physical memory to disk" then reboot itself. it did this about 3 times and then when it started back up it said
"Windows could not start because following file is missing or corrup ... <windows root>\system32\hal.dll > > Please reinstall a copy of the above file."
so i shut it off, and did some digging on what this means. seems to be that boot file gets corrupt sometimes, some have linked it to memory, some to the HDD, some to the MB. most of the fixes seem to involve re-writing code in this file. something beyond me.
so i go back to it and load it upand it starts up fine, just doesnt fully load like the initial problem. just gets to the blue screen with the cursor and stops. its been going for about an hour now.
WTF happened? any help? i took it apart by the book, and same with re-assembly. i didnt break anything, and handled everything with care. all i did between it running fine last night and being messed up was take it apart and install the antenna. thats it.
