My newest project is an 89 HF that will be receiving a B16 shortly... however I need a new wiring harness. When the previous owner had the car, it was stolen and gutted. The plug for the MAP sensor was cut, as well as the ECU plugs. So... I need a new harness.
Can I use a complete, uncut harness from a 90 Civic Wagon? I pulled one earlier today cause I figured since it used the same engine and PGMFI setup as the HF and Si, it would be compatible. All of the plugs are the same, but I have a few left over for the 4WD I assume. I'm also assuming that the 4WD system is handled separately from the ECU, since I haven't seen anything about 4WD in the stuff I've read about ECUs. Please advise!
