Muddy said:
Ok I finally have time to replace it now.
I got to number 8 before getting confused. I don't need to replace the one between the motor and the middle wiper. Just the one from the middle wiper to the right (driver side) wiper.
I can't seem to get the wiper arm connector out. There is a plastic thing that I don't think I can remove that is in the way on the drivers side, and it is screwed down in some way.
Ok I'll try and clear that one up for ya.I wanted you to disconnect the wiper motor because its easier to facilitate the wiper trans removal with the motor out of the way.
I know which one you are talking about.The arm that connects the wiper pivot to pivot not the arm that attaches the motor to the one pivot.Like I said if you pop the motor arm away from the rest you have the room to wiggle the wiper trans asy out.(at least thats how I did it)
As for the cover on the drivers side I had to go back out to the garage and look.All I can say about that cover is you could pop that cover off and theres another air vent thats under that one.You could feasibly try and take the wiper trans out that way,but I didnt do it like that.The first cover is held down by lock clips(it just pops off),but be careful not to break the clips as they are just plastic.
Does that help clear up any questions?
