Thanks Bobski. So with the switch in the ON position, I should be getting 12V to the black/yellow on the dizzy?
I also noticed tonight after more searching around, some use A16->A26 and A18->B02, while others use A16->B02 and A18->A26 for the Logic Grounds. I'm not sure they matter since they're both grounded, but it's worth a shot I guess. Switching those would make sense based on the wire colour from the car harness too, but again, they are both grounds (then again, it seems like a grounding issue with the injectors not working).
Heu, I made the harness myself, and there are a lot of inconsistencies out there as to what does and doesn't work I'm finding. I was checking the pins from the dizzy as well to make sure I have that wired right. Finding a good wiring diagram for the Y7 dizzy is a good time too...
I posted my conversion thing in another thread, but I may as well do it again here, I found this on HT and it seems to be right (with the ground question now, but as it is I haven't changed that yet). I ran wires to the VTEC solenoid, the pressure switch, and grounded the black pressure switch wire to the thermostat ground.
ECU CONVERSION
OBD0 - Function --> OBD1 - Function
A01 - INJ #1 --> A01 - INJ #1
A02 - PG1 --> A23 - PG1
A03 - INJ #2 --> A03 - INJ #2
A04 - PG2 --> A24 - PG2
A05 - INJ #3 --> A05 - INJ #3
A06 - PCS --> A20 - PCS
A07 - INJ #4 --> A02 - INJ #4
A08 - LOCKSOL --> XXXXXXXXXXX
A09 - NOTUSED--> XXXXXXXXXXXX
A10 - EGR CSV--> A11
A11 - IACV --> A09 - IACV
A12 - FLR1 --> A07 - FLR1
A13 - IGP1 --> A25 - IGP1
A14 - FLR2 --> A08 - FLR2
A15 - IGP2 --> B01 - IGP2
A16 - GRD --> A26 - LG1
A17 - NOTUSED--> XXXXXXXXXXXX
A18 - GRD --> B02 - LG2
B01 - VBP --> D01 - VBU
B02 - NOTUSED--> XXXXXXXXXXXX
B03 - ACC --> A15 - ACC
B04 - FANC --> A12 - FANC
B05 - ALT --> A16 - ALT
B06 - MIL --> A13 - MIL
B07 - NOTUSED--> XXXXXXXXXXXX
B08 - ACS --> B05 - ACS
B09 - NOTUSED--> XXXXXXXXXXXX
B10 - CYP P --> B11 - CYP P
B11 - FUSEBOX--> xxxxxxxxxxxx
B12 - CYP M --> B12 - CYP M
B13 - FUSEBOX--> B09 - STARTER
B14 - ALT --> D09 - ALT
B15 - Igniti --> A21 - ICM
B16 - VSS --> B10 - VSS
B17 - Igniti --> A22 - ICM
B18 - NOTUSED--> XXXXXXXXXXXX
B19 - ELD --> D10 - ELD
B20 - SCS --> D04 - SCS
C01 - CKP P --> B15 - CKP P
C02 - CKP M --> B16 - CKP M
C03 - TDC P --> B13 - TDC P
C04 - TDC M --> B14 - TDC M
C05 - IAT --> D15 - IAT
C06 - ECT --> D13 - ECT
C07 - TPS --> D11 - TPS
C08 - EGR VLS--> D12
C09 - PA --> NOTUSEDXXXXX
C10 - BKSW --> D02 - BKSW
C11 - MILGRND--> D17 - MAP
C12 - SG2 --> D22 - SG2
C13 - VCC1 --> D19 - VCC1
C14 - SG1 --> D21 - SG1
C15 - VCC2 --> D20 - VCC2
C16 - O2S --> D14 - PHO2S
Dizzy:
OBD1
1.Orange
2.White
3.Orange/Blue
4.White/Blue
5.Blue/Green
6.Blue/Yellow
7Yellow/Green
8.Black/Yellow
9.Blue
OBD2
1Dark Blue
2White
3Green
4Red
5Yellow
6Black
7Yellow/Green
8Black/Yellow
9Blue
1CYPP
2CYPG
3TDCP
4TDCG
5CKPP
6CKPG
7ICM
8IGN OUTPUT
9TACH OUTPUT
where the large white wire on my harness is substituted for the yellow/green on the OBD1 list.
