I did this a while ago. You need to extend the MAP wires, and the IAT wires. Use your old injectors/resistor box and you should be good to go. I remember needing vacuum caps too... always good to have some vac and coolant hose around.
You can toss them both in the garbage. The only vac lines you NEED are the FPR and brake booster. Rewire the MAP to the one on the throttle body and you're good to go.4G Addict. said:Ok now that I have the wiring all figured out, What do I do about the vacuum lines for the Carbon canister. The other question I was wondering about is the purge cut solenoid thats a part of the old MAP sensor bracket? Can I just un-plug the electrical connector and vacuum line? What does it really do anyways?
I did all this. First, I got rid of my canister. It's cleaner without it and you can still pass etest, hell, i passed mine with no O2 sensor, no TPS, no canister. It almost failed, but it didn't lol. You don't need to lengthen the wires. Simply cut the tape and thug the wires, they will lengthen by 3" enough to reach. The other plug just sorta hangs there. I cut the loom and pulled it all the way back for cleanliness. The MAP sensor verifies proper vacuum in manifold I beleive (Manifold Absolute Pressure, right?). Without it, your car runs horribly and will get 200kms for a full tank of gas...trust me I know...4G Addict. said:Ok now that I have the wiring all figured out, What do I do about the vacuum lines for the Carbon canister. The other question I was wondering about is the purge cut solenoid thats a part of the old MAP sensor bracket? Can I just un-plug the electrical connector and vacuum line? What does it really do anyways?
Thats incredible! With no carbon canister & O2 sensor, the tech should have failed you at the visual inspection before he even hooked the car up. Its cool that you passed though.I did all this. First, I got rid of my canister. It's cleaner without it and you can still pass etest, hell, i passed mine with no O2 sensor, no TPS, no canister. It almost failed, but it didn't lol. You don't need to lengthen the wires. Simply cut the tape and thug the wires, they will lengthen by 3" enough to reach. The other plug just sorta hangs there. I cut the loom and pulled it all the way back for cleanliness. The MAP sensor verifies proper vacuum in manifold I beleive (Manifold Absolute Pressure, right?). Without it, your car runs horribly and will get 200kms for a full tank of gas...trust me I know...
Ya my SOHC ZC was a clean engine. And I went thru a drive thru place, my donut ring had a small leak too. Couldn't hear it so they never bother to checked. The visual inspection hardly ever gets done in the drive thru etesting places I find. Neither my prelude nor civic got one. But what am I complaning about, they both passed.4G Addict. said:Thats incredible! With no carbon canister & O2 sensor, the tech should have failed you at the visual inspection before he even hooked the car up. Its cool that you passed though.
(btw you have a PM)
