Need sum advise
Need sum advise
Postby Uhawkins » Thu May 12, 2016 4:49 am
How's it goin everyone I'm new to Hondas and the crx and don't have much knolege on how to make the increase in horsepower na my crx has a d16a6 I believe the non vtec what parts would get me to 200/250hp na
I also am curious what other Hondas or acuras brakes would be bolt on to get bigger brakes
Thanks for your Tim and help
Uhawkins
Re: Need sum advise
Postby jfrolang » Thu May 12, 2016 10:45 am
200+ HP NA is impossible with a D16A6. Plenty of people have spent plenty of money, and the most successful NA builds get to around 175. Those are race engines BTW, with no consideration given to low-RPM drivability.
Take the whole brake system from a 90-93 Integra.
Consider spell-checking your posts.
jfrolang
Site Admin
Re: Need sum advise
Postby Uhawkins » Thu May 12, 2016 9:56 pm
What would get my hp to around 150/160 would that be possible daily driven ?
Do you know of any good suspension coilovers ?
Thanks.
Uhawkins
Re: Need sum advise
Postby Mista Bone » Thu May 12, 2016 10:41 pm
jfrolang wrote:200+ HP NA is impossible with a D16A6. Plenty of people have spent plenty of money, and the most successful NA builds get to around 175. Those are race engines BTW, with no consideration given to low-RPM drivability.
200+ NA HP has been done, even with a puny D15, but it was for drag racing.
160 whp is possible with stock intake, 170+ with proper intake manifold setup.
But it is NOT cheap. You could buy a ITR swap for less money.
BoneSpec Transmission
"D" Tranny guru
Mista Bone
Re: Need sum advise
Postby Baker » Fri May 13, 2016 7:03 am
Uhawkins wrote:What would get my hp to around 150/160 would that be possible daily driven ?
Swap your motor out with a H22 or b18c5.
Re: Need sum advise
Postby Mista Bone » Fri May 13, 2016 10:18 pm
Is this now Hondatech where everyone just says to swap it????
"D" Tranny guru
Mista Bone
Re: Need sum advise
Postby Uhawkins » Sat May 14, 2016 3:51 am
What vtec heads are compatible ?
Uhawkins
Re: Need sum advise
Postby Baker » Sat May 14, 2016 10:11 pm
Mista Bone wrote:Is this now Hondatech where everyone just says to swap it????
You said it....
Mista Bone wrote:160 whp is possible with stock intake, 170+ with proper intake manifold setup.
Uhawkins wrote:What vtec heads are compatible ?
d16z6 and d16y8.
Re: Need sum advise
Postby kevbo82 » Tue May 17, 2016 8:22 pm
Some silly questions, what are you looking for that much HP for? Why not go force induction or swap, why the naturally aspirated stock motor?
kevbo82
Re: Need sum advise
Postby jfrolang » Wed May 18, 2016 8:39 am
Mista Bone wrote:200+ NA HP has been done, even with a puny D15, but it was for drag racing.
I should clarify that I was talking whp numbers in my post. Without access to an engine dyno it's awful difficult to get accurate crank figures. The best NA D-series builds I've ever seen made mid-170s at the wheels.
jfrolang
Site Admin
Re: Need sum advise
Postby Mista Bone » Thu May 19, 2016 1:11 am
240-250 whp, maybe a little more, but not streetable by normal means.
10.77 in the 1/4 on a NA D15 race build.
"D" Tranny guru
Mista Bone
Re: Need sum advise
Postby Tesla220 » Thu Sep 22, 2016 2:52 pm
Yes. You can swap in a totally stock JDM GSR or ITR and get a true 180Hp with NO mods, no headers, no tune. Just daily drive-ability with tons of power. And keep the AC. why eff [crud] up and hotrod something, spend a fortune then cost $2000 to dyno "Tune"... pain in the azz BS. If you want 160+ it is better to swap.
Chance favors the prepared mind
Tesla220
Re: Need sum advise
Postby hispanicpanic » Thu Sep 22, 2016 6:12 pm
turbo d16. Cheaper and more power. You can reliably put down 200 whp on a turbo'd stock d16
hispanicpanic
Re: Need sum advise
Postby Tesla220 » Fri Sep 23, 2016 9:26 am
hispanicpanic wrote:turbo d16. Cheaper and more power. You can reliably put down 200 whp on a turbo'd stock d16
I like that idea if I could keep my AC
Tesla220
Re: Need sum advise
Postby Myriad » Sun Sep 25, 2016 3:16 pm
Tesla220 wrote: I like that idea if I could keep my AC
The cool thing is that we don't have to fight for A/C and power steering. lol Most people just switch to a half radiator and stick the turbo over the a/c compressor.
The LumberJack and Big Red. It's happening; slowly, but still.
Myriad
Re: Need sum advise
Postby Socal_88crxsi » Sat Jun 03, 2017 8:06 pm
kevbo82 wrote:Some silly questions, what are you looking for that much HP for? Why not go force induction or swap, why the naturally aspirated stock motor?
He's probably some 16 y/o that wants alot of power with little work and money. He's not some n/a purist. Just think that bolting on eBay parts could double his hp
Socal_88crxsi
cron
