joelidge wrote:Thanks. I have run 2 events now with 500 front and 600 rear. I set the alignment back to what I had prior as to not change to many things at once. Thus far this seems to be pretty good. It seems I have increased lat Gs by about a 10th in both peek and steady state and the car is much more forgiving leading me to believe I am not pushing it hard enough. I haven't even spun once with the new setup
I need a few more events to gather enough data to see where I need to go from here but sadly there is only one event left this season. I will be adding big aero this winter so no idea how that is going to change the balance. I still want to try out stiffer front springs but likely wont be until April or May when I have a baseline for the current setup feels like with all the off season changes.
As for natural frequency, it isn't so much a "setup" as a method to derive a setup starting point. To determine the NF, you take your corner weights and spring motion ratio and calculate the spring rate based on the frequency you wish to achieve; generally 2.2hz to 2.4hz for a race setup. This works out to a stiffer spring where there is more weight. It doesn't really factor in swaybars as they don't contribute that much but when you use a Hollis bar with very little flex, the swaybar does impact the steady state setup a bit. In our case, the front would be stiffer than the rear for an NF type setup like Andy outlines in his setup notes.
"Thanks for explaining "NF" Sounds too complicated for an "old school" guy, but I understand what you are saying. I understand the more spring for more weight approach, but there are limits on what the tire can support as far as load applied to it. That's why spring weight are adjusted to achieve a load that will not overload the tire to quickly. Sway bars come into play here as well, and a reason many STS CRX's run without front bar, plus you achieve the stiffness you want with a spring change. And no front bar will allow a non LSD car to have more suspension travel to allow inside wheel to maintain contact longer in a sweeper.
I also understand Andy's approach with regards to rear stiffness. I bought his STC car. Andy also had to consider his co-driver, who did not like a car that oversteers much. So he kept his STC car more neutral than others did. Worked well for him."
For me, when I put on the staggered tires, I had to decrease the stiffness of the rear bar. This made a noticeable difference in slaloms and sweepers as the car is less prone to oversteer and the speed in both increased significantly; the same distance slalom was 5mph faster with the wider tires. I expected the tight stuff to be impacted but the front still has plenty of grip and I can get the rear to rotate in a controlled manor when needed. However, even with the reduced stiffness of the rear bar, I was struggling with was snap oversteer. This has significantly been reduced with the Whitener shocks and stiffer springs. The car can still get loose but it give a little driver feedback when you get close to the edge.
"Snap oversteer can be the result of too high rear pressure, and a tire not up to temp. Some will run a higher rear pressure to induce oversteer, which will work, but can produce a snap oversteer. Oversteer can also be produced from lower rear pressures, usually without a snap oversteer. Again a condition from loading up a tire too quickly."
As for tires, I am running Rival 1.5S. I will get a second set of wheels this winter and likely mount another set of Rivals to have as backups. Once I burn off my current set I will think about Hoosiers but it depends on the local SMF competition. I would rather have someone to compete against than win every event by 4 seconds simply due to tires. One guy is going to Federal FZ-201S 205/50R15 which is a 40TW tire. I don't know how this is going to compare to the wider Rivals so it should be a fun start to the season. Regardless, putting stickier tires on doesn't fix the driver errors and can cover them up so I will probably be sticking to Rivals for most if not all of next season unless I make it out to a national event.
"Use a tire that works for your level of competition, and wallet. Hoosier are the best but are pricey. "
As for the Redshift page, its a really good overview to get a good start in the right direction and is pretty close to what I have already done and my setup.
Locally, none of us in SMF are particularly fast and although we don't have fully preped cars, much of that is the driver. Looking at the data, based on my segment times, I am leaving a quarter to half a second at most events. Looking at others data I can generally find the same or more I left on course. A buddy had a phenom STS driver codrive his CRX in August and he was 4 seconds faster which was on par with the fastest STS cars; that data was enlightening and really helped me improve. I have slowly been closing the gap and I am now about a second behind the top STS guys.
My logical brain just wants to get the car to a confidence inducing state where I can continue to learn and get seat time. I think where the car is presently should good enough to allow for that. However, it is in my DNA to tinker on things; I can't help myself.
