1991 Honda Crx Base ignition stereo wire stays live
Postby Theboy » Mon Feb 13, 2017 1:10 pm
So ive been fighting with this wire for a couple days now. Ive pulled the ignition switch tested the black switch on the bottom and it works. The wires are not burned. Fuses are all fine. I only get the problem when both plugs from the ignition switch are hooked up. So the problem should be happening somewhere after the switch. I noticed I cant put my key in O and that's about as far as I got. I'm debating bypassing the relay (stays enegized so problem is before relay) and hooking up the wire to a switch someone before me installed but never hooked up.
Could it be as simple as my ignition is not aligned? Has anyone had this problem?
Theboy
Re: 1991 Honda Crx Base ignition stereo wire stays live
Postby Theboy » Sat Feb 18, 2017 12:20 pm
Had to realign the ignition switch after that it was fine i guess a previous owner had it in the wrong position when he installed it. i just reset it to 0 and it was fine switch was a lil chewed up but i think itll hold out for a little longer.
Theboy
