My engine is basically a stock D16A6 with a cheap ebay short ram intake. It has always felt sluggish past 5500 rpm. What is the typical bottleneck for power in this situation?
not to be confrontational, however everything I have read about engine theory and design has told me that a cold air intake is better for low rpm torque (usually below 4k).As I Conspire said:-get the cold air.
-4-2-1 headers. no names work fine.
-remove a/c (less pulley usage)
theres some more power squeezed out.
What power steering? :wink:Corksil said:Try disconnecting your power steering
fireant said:![]()
Engine Mods:
- D16A6 head and block, stock pistons, valves, springs, no overbore, new rings and 3-angle valve job
- 92-95 Civic Si head gasket, approx 9.5:1 compression
- 92-95 Civic Si Intake manifold and TB, manifold is DIY stepped just past the throttle body with a dremel
- Head is DIY ported 3/4" deep on the intake side with a dremel to match manifold
- Stock 91 injectors and FPR
- Ignition timing advanced to 22°, 93 octane fuel
- SOHC ZC Camshaft from Carb'd model
- 92-95 Civic Si dampened crank pulley with accessories shaved off
- Iceman short ram intake
- DC Sports 2-pc header, lightly DIY ported at inlets
- Magnflow/Carsound OEM cat
- Greddy SP2 60mm stainless midpipe and muffler
- Stock 91 Si ECU
