801 - 820 of 823 Posts
Discussion starter · #802 ·
Claysonw said:
What are you doing with the old engine?
Donating what I can to the b20, using the head on another motor and selling what's left
Discussion starter · #804 ·
Time for my bi-annual update :lol:
Here's the jdm b20, it's a b20b iirc. Picked it up for $300 8)
I got the engine from jdm engine depot, so according to them it has somewhere around 60k on it. After doing a cylinder leakage test I discovered a valve in cylinder 4 that wasn't sealing completely. Ultimately I decided to just rip apart the engine even though I'm sure it would have ran just fine.
When I had the engine apart I lapped the valves, honed the cylinders, installed new rings, and swapped over my arp head studs and rod bolts from the old engine.This is after I put the b20 back together.
Heart transplant complete
This is what it currently looks like
Right now I'm just trying to get it running properly. I have an xenocron basemap chip in the ecu because Crome was giving me issues and I really don't have time to mess with it. The engine started up first try but it sounded absolutely horrible, and after doing some digging it seems like I either put the timing belt on wrong or it jumped (I'm not sure which to be honest).
After I get it running right it needs an alignment, exhaust, and inspection. With the b20 being a little taller than the ls, my old exhaust doesn't seem like it'll fit so I'll have to figure out something for that. Then I will finally be done working on this thing since I'll be giving it to my brother. Well at least till till it's time to turbo it again :mrgreen:
I haven't decided if I want to keep my other crx or not yet, but need to decide soon since I need a more reliable daily.
Discussion starter · #805 ·
Turns out the timing belt did indeed jump, it is running much better now :mrgreen:
Discussion starter · #806 ·
Bump from the dead :lol:
After a bunch of headaches this thing is finally getting towed this weekend to get an alignment/inspection.
Then time to see if it survives on the dyno 8)
Discussion starter · #809 ·
Then maybe a trip to Eric's meet north of Reading next month??
April 24th - I should be able to make that :mrgreen:
Discussion starter · #810 ·
Towed it to the shop yesterday to get aligned/inspected 8)
Discussion starter · #811 ·
The car finally got tuned 8) Made 122 hp, I don't remember what the torque was. I really wasn't concerned with what it made, I just needed someone who knew what they were doing to tune the car
It was nice to drive it since it's been off the road since November 2013. There were definitely some bugs that came up while tuning it but the tuner (Art at http://www.ycunderground.com/) was really chill about it. It's on eCtune so I can finally do cool stuff like check codes with the gas pedal and use two-step :lol:
After getting it tuned the next day I went to Gifford Pinchot State Park to get some pictures
As of now I need to sort out a few little things but the engine seems to be running strong - it has roughly 100 miles on the rebuild so far and no major issues yet :)b
After a local crx meet on April 24th I'll be officially gifting this car to my younger brother :cry: I really don't have the time right now to give this thing the attention it needs. Looking forward to seeing some of you guys at the meet
Discussion starter · #813 ·
tommy said:
Wow. I'm probably pretty much older than you, but feel free to pretend I'm your younger brother. :D
We can discuss the details at the meet. :)b
Car looks awesome; love that vc.
Yea he's definitely getting lucky 8)
Thanks! It's called 'translucent purple'. It does feel weird having a ls valve cover on a b20b but oh well :lol:
Discussion starter · #814 ·
Saved my 3000th post for some good news - in a few weeks I'll be buying my crx back from my little brother 8) Might drive it for a little bit but it'll be going under the knife again for turbo attempt #2
Aside from little things not a whole lot has changed with the car over the last year. I have my tunerview 2 screen working now, little brother installed a quick release and different steering wheel but iirc that's basically it. Also had my welded engine mount from a few years ago break so replaced it with the updated billet version
Stay tuned gentlemen
Discussion starter · #816 ·
tommy said:
Congrats. Always good to keep a car like that in the family. Niagara is only a couple of months away. :)b
Thanks man, I couldn't be happier to have it back. If the turbo build is done by then I plan on going 8)
Discussion starter · #817 ·
Just picked this up 8)
Borg warner s300sx3, it's a 66/73mm so should be more than enough for my goals (shooting for 600hp)
Current plans although I'm open to suggestions:
- eagle rods
- weisco pistons
- arp headstuds / rod bolts
- honda bearings
- either block filler / posting or css
- supertech valve springs and just lap the valves
- b16 head (already have it with blox intake manifold)
- use current cable ls trans and stage 5 action clutch
- use current 900cc injectors
- use current fuel lab fpr to crank up fuel pressure
- currently have rewired 255 fuel pump, sure I'll need to upgrade this though
- some type of homemade catch can setup
- little brother is a welder so I'll have him make a new manifold and do all ic/exhaust welding
- need to pick a new intercooler since I doubt stock evo9 intercooler would be ideal
Discussion starter · #818 ·
I pulled the b20 out to swap over to my little brother's wagon, also dropped the tank and swapped over the 255 fuel pump. Once the wagon is up and running I'll start working on the crx. One of these days I'll decide on a final parts list so I can start ordering things and put together the new engine
Discussion starter · #819 ·
Alright, finally got this thing in the garage and started ordering parts.
I recently picked up a gsr head so I'll be going with that instead of the b16 head.
Parts on the way:
- action clutch twin disc (going to buy a gsr hydro trans)
- used eagle ls rods / cp pistons 81.5mm 11:0 c/r
- 81.5mm hastings rings
- devcon for filling the block
- -12 an fittings for valve cover
- arp head studs / rod bolts
- blue gates timing belt
- gsr water pump & oil pump
Going to be made:
- top mount divided t4 manifold
- either dual 38mm or 44mm wastegates
- straight 3" exhaust
- intercooler piping
Hoping you guys have some suggestions:
Is it ok to vent valve cover to exhaust? I know this is common in the big block world but it's typically very close to where the exhaust exits the car. I really don't want to deal with a catch can so would prefer to vent the valve cover and block to the exhaust (around where the cat would be) with -12 lines.
Ignition system: Cheapest way to support 7-800 hp without going coil over plug? I've looked into msd blaster coils and the like but don't have any experience going down that route.
Which fuel pump(s) should I use? Was thinking about running a -8 feed line and then using the stock feed as a return. Planning on running e85 and going with bosch 2200cc injectors. A friend was kind enough to donate these to my build but I can buy something else if there isn't an ideal combo here:
2 walbro 255's
Bosch 044
DW 350iL
I was thinking both 255s and the 044 based on this chart:
What am I missing / what's the weak link for 7-800hp? I'm assuming the stock valves and stock cam/intake manifold need to go. Turbo is a Borg warner s300sx3 - 66/73mm, twin scroll, t4 & .91 a/r. From what I've seen in other build threads it should get me in that range.
