Hey guys,
I'm interested in RAISING the ride height of my CRX. Please read on before you reply "why would you want to do that? get a truck!" and other non-related comments.
I am converting (almost finished) my CRX to electric. Yup, gutted the wimpy 1.5L and put something in there that should be equivalent to 250HP+. The problem is that the batteries from my conversion make the car a little heavier than stock, even without an engine and other parts. I put the batteries in such a way that the handling should be like 50/50 weight distribution, but overall the car sits too low now.
I tried to calculate how much weight I'd be adding to buy the right springs ahead of time, but it's a difficult thing to estimate. So I already put on some Tanabe GF210's, which is supposed to be slightly stiffer (still a street car) and only 1.5" lower. Well, it was fine before the batteries but now i'm sitting at 3" of ground clearance and I'd like to improve it a few inches.
Do you guys have any recommendations?
I wondered if I could use some sort of spacer to just raise the body some (like a truck body lift) but I don't want to modify my brake lines. I've already done so much work on the car I just want the fastest way to done. Or should I try to get a spring that has stock ride height and a stiffer spring rate (stock spring rate: 250f/150r, ones I put on there: 336f/200r)? I don't know if I need the higher spring rate as much as one that just isn't lowered from stock, but I doubt they make an aftermarket spring that isn't lowered.
Please help if you can. Thanks!
