Tachometer reads inaccurately and it jumps randomly
7.1K views 9 replies 8 participants last post by  hispanicpanic
I had the same problem and it was solved by replacing the igniter on the cap. You can buy them for pretty cheap and the job can be done in about an hour if you are even a bit handy in the garage. My tach was bouncing like crazy until I replaced the part now it's perfect. Should do it because, unless I'm mistaken, if the igniter goes you'll be stranded and the bouncing tach is symptomatic.
